Well the cat has holes and is leaking on the festiva so I going to have it wacked tomorrow -mob style. The question is should I put a flex pipe in it's place or just a regular pipe? I want this to be a permanent solution with no problems.
Flex pipe do i need it?
Yes. I bought one for my exhaust that is being done this week. It's not the cheap stuff like the dryer vent but a nice one. Plan on $20-25. They come in different lengths to. You might be able to get one long enough to replace the cat without using any more straight pipe.
If you don't you will have more problems later.
It only has around 150k but it sat for quite a while. It was leaking around the flex coupler and on the rear flange where somebody didn't weld it right. Fixed the rear then I felt around the cat and I could feel exhaust coming from the base of the cat.. between the shield and outlet. Not to mention I can basically stick my finger in the cat.. that doesn't sound good. I don't know if something hit it that caused the holes but my dad's is doing the same thing. But up till now that is a first.91 rusty Festiva 260k
The place I normally go to for exhaust work wanted $75 just to remove the cat and $75 for the flex pipe including install... they brought it down to $120 I almost told them where to go and how to get there. Way to much in my opinion.. I could be wrong though?? They wanted that much just to replace the cat almost 6 months ago.. that made since. I guess I have to find a new place to get my exhaust work.91 rusty Festiva 260k
Remember that a catalytic core is worth $... which is something they're not telling you. It has platinum or some such rare metals in it, let 'em know, or do it yourself. I will not take my car to any mechanic till I am very old or very rich :lol: Good luck.4-spd 1989 Festiva - carburated baby!
yeah, a fouled, 150k mile cat is worth a whopping $10-$20 core value. Keep in mind, the shop has operating costs to meet. $120 for parts and labor really doesn't sound unreasonable. Hell, around here, that's cheap. But then again, us Festiva owners are notoriously cheap.... I mean, after all, we are driving Festivas!
Jim DeAngelis
kittens give Morbo gas!!
Well I talked to another shop and they were able to cut the flange off of the cat and weld a pipe to that flange -$50. Basically uses the stock flex setup. Without the cat it sounds like a sounds really wicked :shock: . Didn't notice much performance except around 5k or so.91 rusty Festiva 260k
