I'm stumped... Put a tach cluster in my 90L. Tach works fine but the speedo does not. Needle is jumpy all the time. Seems like the gear and cable are good cause the non tach cluster speedo works fine. Makes one think the tach cluster speedo is faulty..but when I hook the tach cluster speedo to the cable and a cordless drill on a bench top it works fine. One thing I did notice is that the tach cluster is about an inch thicker than the non tach cluster...makes me think that's causing the cable to be to long by an inch and possibly binding inside. Anyone experience this or have any suggestions?
Thanks,
Tex
Thanks,
Tex
