What is wrong with my 1988 festiva if the rims get really hot to the point where they start smoking? brake calipers and outer bearings were already recently replaced.
Hot Front Rims
Grease is either split CV boots, or more likely, bearing grease that got too hot and got runny and got slung out past the seal.1963 Fairlane - future NSS drag car
If the bearings were not preloaded correctly that may cause the issue. They may possibly be too tight. I had loosely preloaded bearings on my aspire for about six years with the only problem being a slight drift on a lumpy road or a shimmy at highway speeds. Never got hot. Once I saw someone at work leave out the preload spacer and the wheel was locking up due to the excessive friction. Also what the previous poster mentioned about a collapsed brake hose. More than likely they are now collapsing due to the excessive heat so once the root cause is identified I would recommend replacing the hoses as a precautionary measure to ensure no further issue. Did this problem occur before the wheel bearing replacement or was the replacement a repair attempt at the heat problem. If the bearings are to tight they may need to be replaced due to galling or welding themselves to the hub which would require a set of junkyard knuckles. As far as general bearing replacement goes I would recommend replacing the inner and outer bearings and races at the same time. Why change just the one when the other has the same amount of wear and fatigue and it's already apart. Good luck.Last edited by Aspire SVT; 08-06-2011, 01:01 AM.Tim
'97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
'03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
'95 SVT Aspire B3T, Green Mica, 75k miles - DD
'01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
'89 Suzuki FA50 Bright Red - Lake Transportation
Cardomain.com/id/aspiresvt
Previous Vehicles
'92 Festiva L "Sport" Green Mica
'92 Festiva GL Blue Pearl
'92 Capri XR2 Performance Red
Originally posted by JIMITHING View PostWhat is wrong with my 1988 festiva if the rims get really hot to the point where they start smoking? brake calipers and outer bearings were already recently replaced.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
If the bearings were changed previously, and the spacers switched up, if you redo it, how do you know where to put them? I've only ever dealt with tapered bearings.1963 Fairlane - future NSS drag car
not to start anything, but why in the world would you only do the outer front bearings and not the inners as well (takes another 3 minutes per side). that's just asking for trouble.Trees aren't kind to me...
Originally posted by Larry Hampton View PostIf the bearings were changed previously, and the spacers switched up, if you redo it, how do you know where to put them? I've only ever dealt with tapered bearings.Last edited by nitrofarm; 08-08-2011, 09:50 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Not to step on any toes but I believe the unit of measure for Rotating torque is measured in inch-lbs. Just figured id add to avoid confusion. If it was measured in ft lbs it would be 12 times too tight and the bearings would be junk. I bought a special torque wrench just to set up my aspire ones. I have part numbers for the spacers. if anyone needs them kia still supplies them. I bought all 21 of them.. <--- Psycho...!! The numbers are also posted on the forum.Tim
Previous Vehicles
Originally posted by Aspire SVT View PostNot to step on any toes but I believe the unit of measure for Rotating torque is measured in inch-lbs. Just figured id add to avoid confusion. If it was measured in ft lbs it would be 12 times too tight and the bearings would be junk. I bought a special torque wrench just to set up my aspire ones. I have part numbers for the spacers. if anyone needs them kia still supplies them. I bought all 21 of them.. <--- Psycho...!! The numbers are also posted on the forum.
The one pic with the "C" Clamp I'm using the old bearings to press in the new races. Works nice and smooth.
Last edited by nitrofarm; 08-09-2011, 11:24 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
