Last year, a/c went out on RollazX. She is an '90 or newer evidence 1.6 , 5 speed, lowered. Etc. Replaced the compressor after determining leaks were inside it. Recharged system to 21 lbs of 25 lbs (or whatever unit of measure is used for fake freon) per recommendation on here. Works great and cold. Problem, a/c cycles through to fast. Cold for 30 seconds, shuts off for 30 seconds.....and repeat. My mechanic says most cars have an adjuster to fix cycling problem. Do Festers have one? If not, how do I fix above situation?
Thanks in advance,
Dan "Levitan"
Thanks in advance,
Dan "Levitan"
