I just set the cam timing on a 92 Festiva. The problem I have is that the car starts but will not stay running. I set the cam timing retarded one tooth on the camshaft, then I advanced it one tooth and still the same. I checked the fuel supply, when the key turned to the run position there is no fuel coming out of the fuel filter, it only pumps when the motor is turning over. Sometimes the engine will run if you keep pumping the gas peddle, but it is like the engine is being starved for fuel. The question I have is where is the fuel relay is located or where or what color are the wires are for the fuel pump as i plan to jump out the fuel relay.
Thanks
Thanks
