My carbureted '89 Festiva keeps pushing oil from the valve cover into the air cleaner. It is not a whole lot but it is enough to lay in the bottom of the air cleaner & get on the air filter. The PCV valve is new and the oil is coming from the hose that goes from the valve cover into the air cleaner. The car has 150,000 original miles on it.
Has anyone else had this problem? What did you do to solve it?
