dome light w/ map light
  • dome light w/ map light
    Installed dome light today. Map lights work. Dome light works when door is open. Dome light doesn't light when switched to the on position. Could switch not making contact, or maybe bad switch, or maybe wrong bulb? Should bulb have 2 filaments,1 for when the door is open and another for the on position?
    the bulb only has one filament
    your problem lies in your switch not making proper contact
      Thanks for the info. Also I noticed that if you turn on both map lights the dome light comes on. Is this normal?
