Okay so I know the drivers side cv axle is really bad, but can that cause my steering to shudder constantly going down the road, and when I brake, and cause my car to to be pulled back and forth at higher speeds?
Also it feels like when I turn to one way it turns alot faster, and when i turn the other way its not as abrupt. You know if I just wiggle my steering a inch in either direction, almost feels like it toe's in harder on one side.
I know my Tie rod ends arn't the best either. I have new parts for both buy im nervouse about pulling out the axle to replace it, is it hard? I know I have to take off the wheel, how does the axle end in the tranny come out, and do I have to put anything (like a broom stick) in the tranny hole while im switching them? Also the other end is just held to the hub by the axle nut right?
Logan
Logan
