just noticed that my spark plug leads are starting to crack and one i can start to see the wires on #2 so they gotta be replaced, does any one know of any performance leads to fit festivas?
performance leads
magnacaores.....give FMS number a call you can get denso plugs too with the wires for about 50 bucks---------------------------------------------------
Since you're in Australia, I don't imagine you want to ship from US. Most auto parts places here have 8mm silicone wires. I imagine you can find them locally, there, too. Like WES said, Magnacores are the best, but really, unless you have a HIPO Festy, any 8mm silicone wire (i.e. Bosch) should be fine.
jeff
I bought ignition wires with a lifetime warranty from the national auto parts discount retailer and kept the receipt. I have replaced them once at no cost when one was damaged while working on the engine.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I prefer Taylor wires. IMO, the best you can get.Dan
I am going to change the wires but, I thought I would check the coil first. (ohms - resistance). The primary reading is: 2.3 ohms. And the secondary reading is: 11,810 ohms. Is this coil good or it needs replacement?:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
That is so true... They last forever. But will it makes a difference between stock originals leads cost about. $30 and some, so called high performance racing ones cost more than $80?Originally posted by bhazard View PostPretty much anything will work with the B3.:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
Theyre basically just overbuilt. More insulated, maybe better conductor, but its not really gonna benefit a b3 much. Its like getting a b6t or bp festiva without ever having intentions of going fast.91GL BP/F3A with boost
