Alright guys... when I bought my festiva the alternator wasn't charging the battery and when hooked up to a multimetre at the battery was reading between 4-20 volts.
I replaced it with one courtesy of M3NTAL hoping to fix the problem. And it did! After installing it I was getting a steady reading of 14.2 volts at my subwoofer amp (which before was at or below 12V)
Only problem, is today when I was driving, when I had the brake lights on and a turn signal, my head unit/deck would turn off then instantly turn back on... a sign of not having enough power. Later I was driving, now with the headlights on, and the problem persisted. While waiting for a friend at his house, I jumped out, and the amp was reading 10.5 volts, with all electronics off but the car still running!
I have no idea what is going on. I assume I should get my old alternator tested at a shop because for some reason I think it isn't the alternator but some wiring along the way. What really bugs me is that the new alternator was charging steadily and then BOOM it wasn't the next day.
Is my festiva an alternator killer??
