I've got oil sprayin' on the underside of hood above timeing belt cover. Could this be the cam seal? if not what? Just startedFri.
Oil leak/spray
Pull the cover. if you've got oil leaking from there, it's possible that the leak is elsewhere and the cam gear is spinning it out where the cover seal isn't 100%.In love with a MadScientist!:thumbright:
Im losing about they same amount but not spraying ljme above postOriginally posted by korey_gunn View PostI have same problem...im loosing about a quart every 2 days. let me know what you find please! Korey
Sent from my PC36100 using Tapatalk
