Well, really just singular. And what could the issue be? It leaks, of course. I never had any interest in owning a Festiva with a sunroof, but my new '90L came with one (who would order a stick L with a sunroof and air, anyway??). It appears to be factory - there's a bright rose-colored surround band in the interior, if that says anything, and it didn't seem to leak during the first few rains, but now it develops that if I park with the left nose down, enough water pools in the roof that it leaks there.
What I can see of the seal looks very good, but the leak is at the leading edge where the hinges are, so the question is whether the sunroof panel can be removed completely by somehow flipping what appear to possibly (??) be release levers on the front two hinges, or if I need to unscrew them - I'd like to gently clean the gasket with soap & water to see if that will help. Of course I suppose I can figure this out by playing around a bit, but I thought there's a chance that someone else has one with a factory sunroof.
Also, any suggestions on what to do with the seal to help preserve it, and/or whether there's any source for new gaskets, since in the probably unlikely event that they are available somewhere, a spare gasket would be good for peace of mind.
