Weird Electrical Issue
  • Weird Electrical Issue
    So I have a strange issue that has been going on for several months.
    Basically if the car is off with key out I can still turn on my Windshield wipers, Heater, and my rad fan used to stay on until I put in a toggle (which I needed anyway).
    Anyone have any ideas?
    My Musica! Click me!
    Bad ignition switch? Leaving the accessory circuit on.
    -Zack
      I concur with crazyrog17. Only way that could happen.
      1990 White L-Plus 5-speed rust-machine
      Scrapped
      1991 Blue L 5-speed
      daily driver, intermittent project
      1993 rustless wonder
      A shell, awaiting suspension, brakes, and B6T
        Ahh that makes sense. Thanks guys, I'll check it out.
          X3
          You should buy a multimeter, not that expensive and the best for diagnosing electrical issues.
          93 Ford Festiva WA (project car)
          98 Ford Festiva WF (aspire)(parts car)
          98 "Gloria" Toyota Corolla AE101 (daily driver)
            Originally posted by NicholasJackson View Post
            X3
            Yeah I have one.... But it's at home and I'm at school for quite a while. I just want to make sure everything is squared away for FMV!
              Squirt some WD-40 into the ignition key hole and work it around with the key. I've cured an ignition problem that way. If it does no good it'll do no harm.
                Cool I'll give that a shot first. It hasn't really been an issue as long as I don't leave something on :p Hopefully the wd-40 will do the trick.
