Car swerves by itself
  • #16
    Originally posted by DriverOne View Post
    How far should I travel before testing the hub surface temp? where would I find a spacer sel. tool, and what's the procedure for determining correct spacer size?
    you have to dissasemble the knuckle/hub and remove the bearings to inspect for the gauling/hot spots. you can still find the selection tool on the 'Bay.
    • #17
      Every bushing in the front end has to be good in order to stabilize it. Also the ball joints and the rack and the motor mounts. The wheels are "suspended" among all these pieces. There can be no slop.
      • #18
        Aslo, before you torque the LCA to sway bar bushing bolts, set the car down off the jackstands. It can make the car feel a little squirrelly.
        No festiva for me ATM...
