ok so here's the deal, i bought a little red automatic festy, im driving it around, it chuggs a little but not a problem. one day im driving it and it dies, i wait 5 mins and then it starts up again, ok wierd, then this happens a few more times and then wont start again. i park it and come back the next day with all new ignition parts, (new distributer, cap, rotor, igniter, coil, spark plugs, wires, everything that can be changed i did) ok car starts, i drive it maybe 5 blocks and it dies, damn i cant figure it out, spent all day with the haynes manual checking everything, finally find out that the wiring harness for the igniter, the actual plug on the harness is what is giving me trouble, if i wiggle it the car shuts off, if i wiggle it again, i can start it, but the fuse in the engine bay ( you know those 3 wires that act as fuses on the drivers side shock tower) the one fuse maked MAIN, keeps getting hot and burning, so i assume theres a short in the wiring harness, except the main fuse is attached to so many things, im in the process of ripping out the wiring harness and tracing the igniter harness back to where it connects to the main harness.
anyone have any ideas of why this happened or had similar experience?
Thanks, Emerson.
Thanks, Emerson.
