Spudder
  • Spudder
    My car has a spudder to it. Like when I give it gas I hear a spudder sound from they tail pipe. Could this be spark plugs?
    Sent from my PC36100 using Tapatalk
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    The sputter is probably a hole in the exhaust system. When the engine is running and with the wheels blocked, look under the car for signs of escaping exhaust. If you can, get someone to step on the gas to make any leaking fumes more visible. It shows up better on a cold day in the morning.
      Hold a rag over the tail pipe and look/listen for escaping exhaust.
        Is it just a noise or does the engine seem to sputter? if it's the engine sputtering it's the cap, rotor and wires. Any one or all of those will cause a sputter. Very common problem with these cars especially when it's wet out.
          .... Well spoken, like a true Festie owner.:thumbright:
          A hunch is creativity trying to tell you something.
            They engine sputters too.
            First time owner
              For the ingiton system wipe the wires and cap with a clean rag and see it that helps. If not you can pull the wires and crimp the ends a bit with a pair of pliers for a better contact with the spark plugs and cap. If that doesn't work pull the spark pugs, clean, and check the gap. If that works you've fixed the problem without spending any money. I clean the wires on my car once or twice a year when I do a tuneup.
                1. Spudder
                The sound made by a blast of diarrhea hitting the sides of the toilet bowl.
                "I went into the bathroom at school and the person in the stall next to me must have been sick. All i could hear was one spudder after another.
                Thank you Urban Dictionary!
                Oscar
                  Originally posted by perucho View Post
                  1. Spudder
                  Lol. Well someone did say my car was a pile of excrement.
                  First time owner
                    Sorry for the language. Wont happen again.
                    sent from my EVO hacked with Vaelpak GB AOSP with Tiamat 3.3.7 Kernel
                    First time owner
                      I took out spark plugs and looked at them. 2 of them looked ok. But 2 of them had some kind of build up in the hole on the spark plug itself. Looks like a black cement caked in there. Hard as a rock. I'll see if that helps any.
                      First time owner
                        also check the condition of your coil... you could have arching at the secondary tower.
                          It spudder sound is gone and it seems like its got more power than it did. I'll check gas mileage this week.
                          First time owner
