temp sensor help
  • temp sensor help
    Hey, so I just finished my bp swap. My temp sensor idnt working, can some take some pictures of which temp sensor goes where, and which wires go where, it would be much appreciated
    :cry_smile: RIP. 91 Ford festiva BP swap
    1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
    I don't know if the b6t is the same as the bp but it is located on the back of the thermostat housing and is a single wire plug that slips over a brass nipple.
    91 Festiva BP Autocross/Track/Rallycross hopeful
    14 C7 Z51
      I have location but I'm confused to as which sendors were used
        come on no one can help me? i wanna get this figured out so i can drive it longer distances without worrying, anything is appreciated
          So you need to know what goes onto the nipple?
          14 C7 Z51
            I somehow have three temp sensors, one with a green plug off of the injector harness, and on with a slide onflat slip. I also have one not plugged into anything on the harness the is like a brass dowel. i dont know which one i can put the "dowel one into because the thread sizes dont match, What does it take to get a temp reading on a bp festiva
              Ok sorry the bp isn't set up the same as the b6t. Somebody help him!
              14 C7 Z51
                The green one on the injector harness is the one you peel back from the passenger side of the festiva injector harness (easy enough, it has the same plug and its the only one like that). the dowel one is the temp sender for the cluster, the spade on the thermostat housing is for the fan relay.
                Happen to have any pics on hand? if not ill go take some snaps of mine first thing in the morning.
                1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
                  The Green on off the Ejector harness does not get used, correct?
                  91 Festiva, BP, auto
                  69 Mercury Cyclone CJ, 428 SCJ, 4 spd
