My unregistered '92 sits for long periods. It has developed a sticking HLA that won't go away from driving it around my neighborhood. I was wondering if the earlier adjustable arms or whole shaft can be put on the later head. I don't mind adjusting the valves every couple years.
Rocker Interchangeability
HLA are probably just low on oil and deposits are keeping the oil from getting in to pump them up.
An oil change to thinner weight oil might help and/or Seafoam® before the oil change may help remove these deposits.Last edited by Pu241; 09-20-2011, 03:43 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^^ how did you get that little trade mark insignia?
I agree, add a little Seafoam (insert trademark sign here) and drive it for a couple hundred miles, then change the oil.Brian
LOL
I have to use a bunch of special symbols nearly everyday.
The character map contains them, all but I remember those I use a lot:
ALT+0174 = Registered Trade Mark = ®
ALT+0176 = degree symbol = °
Also would haven been more appropriate had the ® been in superscript, but can't determine if this editor has that ability.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I think they are interchangeable because my engine was rebuilt and has the older 88-89 adjustable with springs vs the later with HLA's and hard spacers. I'm not 100% but at the same time, Nate told me I could swap to HLA's whenever I want so sounds like a win to me.
if you type ® in sup in WORD or something and then copy it maybe it will take. I've done that with strikethrough since I don't recall it having strikethrough and it worked. Never posted it but I would think if it puts it in the text box then it'll post too...
the earlier ones literally move side to side and have springs that try to keep them seated, they work. But also you know they're adjustable? The later (is it 90+?) have non adjustable HLA's and they are in place with like 1/2" or longer hard spacers.
I'll probably some time switch my car back to them. Looking up it looks like I already answered that. good job reading george
