O'Reilly had some battery cable fittings, but they were clearly intended for much larger diameter wire than in Festies. I'll hit up AutoZone and Napa on Friday, as well as the only remaining good electronic components store left in the area.
Instead of trying to wire-brush existing cable to buy some time, I saw some YouTubes that show that vinegar+salt followed by baking soda+water is an effective way to clean metal contacts, wire crimp connections, and the, so will give that a try.
So you're saying that the O.D. of posts on our batteries is smaller than "normal?" That explains why the fittings a prior owner clamped onto my cables are so difficult to snug up!!! I'll bring a battery with me to parts stores for test-fitting. If I recall correctly, we use "Type 35" -- does that imply not only overall dimensions but also post O.D.?
