Today my wife drove the car with the gas gauge way under the red empty mark and luckily got to her friends house. She told me I need to fill it up because it was empty. I tried to start it and it ran like crap and kept cutting out. So I went to get 4 gallons of gas and put it in the tank. It just kept cranking but would not catch.
Inertia switch is depressed and I also removed fuel line from fuel filter and turned key on, no fuel flow at all. This leads me to believe the fuel pump is bad. But, I don't hear anything under the dash, ie: relay clicking when I turn the key on or cranking. So, it makes me think it may also be a bad relay. But because it ran earlier and kept dying, it makes me thinks its the fuel pump and not the relay. Haven't had a chance to check for voltage at relay yet.
I read in a post that Festyboy said, on Festivas, the pump doesn't energize when the key is on, only when cranking so I'm thinking its the same on Aspires. I ordered a pump with lifetime warranty from the Egay because the car does have 163,000 miles on it and it wouldn't hurt to replace the fuel pump since its only $22.
So, does everybody think its more likely the relay or fuel pump?
