Ever since I bought my 1994 Aspire about a year ago, I noticed that the car would buck rather severely when starting in 1st gear. Since I was able to avoid the bucking by careful use of the clutch and I had much more pressing problems with the car, I decided to put off doing anything about it.
The problem has gotten worse and I now want to address it. The clutch does not slip and I think the bucking comes from a rhythmic back and forth rotation of the engine on the motor mounts.
When I pry up on the motor mount brackets, the back one hardly moves at all. But, while using the same large screwdriver, the front mount is so easy to lift up that it appears to be bearing hardly any of the weight of the engine. I think this is where the movement is coming from. I can see that the front mount is not torn, though I suspect its firmness has been compromised by all the bucking. My feeling is that the engine would stabilize if more of its weight was resting on the front support.
Here is my first question:
My assumption is that when the engine is lowered into the engine bay it is supported at only three places, the three through bolts of the three motor mounts. Is that correct?
Next question:
Without the exhaust being connected to the catalytic converter, what is the relative percentage of weight supported by the front and back supports?
Question three:
When the down pipe is connected to the cat is it possible for the weight of the exhaust system to act as a lever to lift the front of the engine and cause all weight to be transferred to the back support?
Number four:
I've read about "normalizing" the mounts and the exhaust system by loosening all the attaching nuts and bolts and rocking the engine back and forth, slipping the clutch in first and reverse with the brakes on. Would this be an appropriate action for me to take?
I have never had a car that caused me to give any thought to its motor mounts, so all this is new to me. Any suggestions would be appreciated.
Next question:
Question three:
Number four:
(jk)
Good Luck & Happy Holidays.
