Not sure where to post so forgive me if in wrong place. Newbie!!!
While checking for loose wires etc under hood noticed that a wire was loose. After checking the manual i found that it should be connected to fluid pressure switch on the power steering pump. The top of the switch was not where it could be connected to the the wire. What is the harm without this connection?
I am more of a shadetree mechanic type so thanks in advance. I have another plea for help later.
