Could someone with a '92 or '93 man trans Festiva peek at their starter and see if it has a thin wire on the post with the battery cable? I would be 100 percent sure that's where it goes if it wasn't for a possible ground to a trans bolt nearby.That bolt was loose because of a harness bracket removed during the engine/trans R and R. I surely don't want to have unfused 12 volts going to something that should have been grounded. Thanx
Another wire reattaching question
It's hard to be sure here, it could be a positive or a negative.
Best bet is to not hook it up and use a test light, multimeter.
Yet on my 91 with automatic, it has two wires on the positive starter post.
On my 90 with a standard trans, it has only one, this is obviously the battery cable.
If your unsure, it's best to test it for continuity. Only way to be safe and not fry anything.
