Finally got everything hooked up on '93. Won't start. Have spark. Injectors clicking. Pulled pressure hose, gas sprays. Starts on ether. Checked return side: Nothing. Worked VAF, pump running, no gas out return hose. Pressure regulator completely blocked? Seems like it would at least start with pressure in fuel rail. Lost.
fuel mystery
Fuel inlet goes into the rail and the return goes from the regulator back to the tank, im pretty sure.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
2xOriginally posted by shadetree View PostSeems like the lines are backwards
Happens to the best of us, sometimes more than once!'93 Blue 5spd 230K(down for clutch and overall maintanence)
We (me and daniel) have done 2 bp swaps, like 5 b3 swaps, and a couple b8 swaps and everytime, we end up doing this. Most of the time a good blast of fuel in the face lets us know that the lines are backwards lmao.Originally posted by Pu241 View Post2x
Happens to the best of us, sometimes more than once!89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
I put fuelines on backwards when i did my b8 swap did the same thing so take everyones advice and let us kno your results!93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
Timing belt skipped? Kinda need more info.And those clips are available thru napa for cheap.Originally posted by georgeb View PostSo where do I start with a situation where it has spark but wont run on ether? Also, I lost a CV clip and have the inner cup held into the trans with a broom. Does anyone have any laying around? Thanx.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
