D is working on a Festiva that is not getting any spark to the coil or the plugs. Any suggestions would be helpful. If you want to call him his number is 952-484-5447.
No spark to plugs or coil...
well actually before swapping the dizzy, take some carb clean to the inside of the dizzy UNDER the dust cap that's under the rotor. hose it down really well if you see anything black come out on the initial spray. likely the pick up coil is covered in oil and loosing signal. also make usure the EGI fuse is good and the coil is getting battery voltage.Trees aren't kind to me...
