leaking oil? It is on the back of the engine above and to the left of the oil filter....oh....it is on the B6T,
91GL Green Auto DD There ain't no rest for the wicked
until we close our eyes for good. I will sleep when I die!
Knock sensor. Not leaking oil. Its filled with some sort of resin
ok....but it is dripping oil from inside it...not a lot but it is.
IIRC the port that the sensor screws into is dry (not an oil pressure port). the "fluid" you see may be an internal iso-fluid for the sensor itself.
i have NEVER seen a knock sensor linked to any fluid port on any engine and having one do so would make 0 sense as the noise from the oil would cushin the noise and distort it.
the oil pressure sensor on a festy looks like the B6T knock sensor because it's just an "on-off" switch style (closed with a minimum pressure of 4-6psi) and it controls the idiot light. the one on a capri is a swing style that sends a signal to a sweep style gauge.
