Alrighty.
Recent fixes:
Used gas tank installed
Rear hubs
New tires
New left rear bearing
1990 Ford Festiva L-Plus Auto
I have several things going at once, so I have a lot of questions.
Fuel gauge does not work. Have tightened rear screws (all screws behind instrument cluster), checked sending unit floaty-thingy, meter fuse looks okay. No dice yet, and am wondering what to try next.
Temp gauge doesn't work, which scares me a bit. Bought an after-market gauge, but it's ugly and don't really want to use it unless I 100% have to. Don't even know where to mount the darn thing.
Check Engine light comes on randomly (for maybe 2-5 minutes tops), originally thought it was because a short in the radiator fan switch (P.O. put in a switch inside the car instead of replacing whatever it is that turns it on automatically), and someone helped me rig the switch up correctly, even put it beside the steering wheel instead of on the floor. Also want the temp gauge working so I don't have to have the fan on 100%. This is a Festiva, and I want my fuel savings.
There isn't a cat on it and am wondering if it could be an emissions issue.
Only did this a few times, maybe three: acceleration cuts out for half a second, only when coming from a slow or dead stop. Down the highway it has quite a bit of pep and the transmission shifts smoothly from there. Once after this the Check Engine light came on again.
I'm sure there's something else... oh, well. One thread at a time.
~Spike
Recent fixes:
Rear hubs
New tires
There isn't a cat on it and am wondering if it could be an emissions issue.Only did this a few times, maybe three: acceleration cuts out for half a second, only when coming from a slow or dead stop. Down the highway it has quite a bit of pep and the transmission shifts smoothly from there. Once after this the Check Engine light came on again.
~Spike
