rear drum wheel bearing preload?
  • rear drum wheel bearing preload?
    does anybody know what the torque setting is for the rear drum bearing lock nut thx?
    1989 Miitsubishi Mirage turbo RS, 4G61T, smic, 3"S.S. 13g, EBC,
    89 LX carb Festy, 5spd, 106xxxkms, 2nd owner.
    ........Let boost be with you
    and bring some timing too........
    I believe it is in the 20-25ftlb range it is not that tight... -Kyle
    Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
    White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
    Proud member of Chicken Mechanix Racing
      It's actually 2-5lbs, actually hand tight. After you install the repack bearings tighten it down 50-60lbs while turning it stop when you can't turn it anymore. Back it off, start turning it and retighten with your hand as much as you can. That's what I did on the aspire worked good.
      91 rusty Festiva 260k
