I just swapped the engine due to bad rings, it was doing this before but i figured with the newer engine it would take care of this issue .. It's idling up then dropping down then up then down then it will idle normal and sounds like its missing . It has new plugs and wires and runs perfect while driving no issue at all till you stop and let idle .. check engine light comes on and will clear with disconnecting the battery .
Any ideas
Any ideas
