CAN YOU CHANGE THE CRANK SEAL BY JUST REMOVING THE PULLEY OR IS THERE MORE TO IT. 90 L PLUS 5 SPEED MANUAL. THANK YOU STEVE WINTERSET IA
CRANK SEAL HELP
Welcome Steve
Now please use your inside voice!
Take a look under search/advanced and do a search or two to see what turns up.
This has been addressed numerous times.
I'm sure there is more than one description of what you are looking for.
If you can't find what you need, please pop back here and well see what we can do for you.'93 Blue 5spd 230K(down for clutch and overall maintanence)
crank seal
x2 on the inside voice. Your on track Steve, remove the v belt pully, the timing belt cog pully and your there. Be carefull not to gouge the crank snout when you remove the old seal. Has Winterset had the Covered Bridge Festval yet. Give me a shout if you need some help.An idea can turn to dust or magic, depending on the talent that rubs against it.
to help remove the seal, you can screw 2 or 3 sheet metal screws into the face of the seal and wiggle it out that way.Trees aren't kind to me...
