anyone know what color the y/bk wire from dis turns to at the firewall to goto the ecu
No fire at coil
Its the 12v for the CPS, inside dizzy. Its fed from Two relays. The "Main Relay" & the Fuel Pump Relay". It changes color to Y/BL after it goes through CPS then to ECA. The BK @ the Dizzy is obviously Grd. Hope this helps.Originally posted by Toxic90fest View Postanyone know what color the y/bk wire from dis turns to at the firewall to goto the ecuLast edited by Pu241; 10-15-2011, 02:59 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Try a CORONA with a fresh lime. I've found Festiva's like em. But they also like Dark beer as well. Especially during OktoberFESTY.Originally posted by Toxic90fest View Postim really lost at this point any ideas would help greatly. im at about the point that its just goin to sit in the back yard n rust to death
why are you pulling the dash?Trees aren't kind to me...
WHY.....?Originally posted by Toxic90fest View Postaright got everything under dash fixed n new pcm installed now i have fire at coil but now im positive my fuel pump is shotSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Did you dry the water up where it ran thru a puddle? Should run fine if you did....?!?!2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
tap on the injector first and inspect the plug for fuel fowling. also check the condition of the spark at that cyl with a NEW plug and a compression check.Last edited by FestYboy; 10-23-2011, 07:12 PM.Trees aren't kind to me...
