I need to replace my fuel filter soon so I was thinking I can get some section of steel line and longer fuel injection hoses and put the filter up top somewhere. Has anybody done this?
Anybody relocate their fuel filter up top?
I used a long section of fuel rubber line and mines where the aspire one is, just because the aspire filter I had was still new. There are rubber lines at the rail on the top of the engine held with the same exact clamps, so as long as you don't pinch them or put it together in a hurry you won't leak no matter where you locate pieces.1993 GL 5 speed
Can use the Aspire setup directly.
It moves the filter to a more convenient location.'93 Blue 5spd 230K(down for clutch and overall maintanence)
good call John.
you could also get a fuel filter that doesn't have to go in from the bottom. but one that just slides down into the holder and seats on the top lip. won't fall out. that's the route I went. next time I replace the filter it'll probably take about 3 minutes instead 15+
I have mine loosely zip-tied under the brake m/c. I can just undo the two hoses and slip the filter out of the two zip ties. Only about a minute to replace it.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Mine is located in the car with me so I can change it while I drive.Festiva: Because even my dog can build a Honda.
Originally posted by JPT View PostMine is located in the car with me so I can change it while I drive.
lol riiiiiiiiiiiight good luck with that
