Temperature sender
  • Temperature sender
    Could someone tell me where the sender is located for the temp gage. Are there 2 temp senders? Also where is the oil pressure sender? This is an 88.
    Thanks
    water temp gauge sending unit is located on the head closest to the exhaust manifold. should have a round spear like connection (its SMALL). there is the temp sensor on the botom of the intake as well (green plug?). and then the fan switch right next to the gauge sending unit (is larger and has a male spade connection). the oil pressure SWITCH is located to the left and above the oil filter.
