daytime running lights
  • daytime running lights
    i have a 92 L with no daytime running lights .i need them to pass the safety and am wondering where the drl relay and the drl module are located? are they under the dash or the hood? i'm thinking i have a cut wire because the kid i bought it from put those blue headlight bulbs in there. i'm in Winnipeg and they are required to work.anyones help would be greatly appreciated thanks!
    Stock 92 5speed,14"wheels,drls ha,cat deleted,bigger pipe,stock muffler.
    Navy w/blue metalflake and 3 spoke chromies,185/60/14
    Debadged
    I may be wrong, but I don't think Festys have DRLs. My '93 L doesn't. I checked the post on Standard & Optional Equiptment & they are not listed, even as a Canadian option.
    '93 Green L - ' Tiva
      Not an option... Canada Motor Vehicle Safety Standard 108 requires DRLs on all new vehicles made or imported after January 1, 1990. I know my Festiva has them, it's a '92. I'm assuming that all Canadian Festivas of the 1990 model year and newer would have them too.
      DRL module is located in the middle of the firewall. Don't have a pic right now but I'm sure another Canadian member would be able to help.
      Ian
        DRLs weren't an option on Festivas... You'll have to install the system. What a bunch of Bull squat! I don't think I've ever actually seen an aftermarket setup either... *Goes to look* Here's a set!
          man, you guys from the States have to do your research! As Fastivaca said, the modual is located directly behind the intake manifold on the firewall (above the pinchweld). IIRC it contains the resistor and relay in one unit.
          nav and Driver, that's a factory installed unit for those sold in Canada, NOT a dealer installed or aftermarket piece.
            well i found the module... but there is no power going to it . i wonder what he cut lol you should have seen the stereo ha,thanks for the input
            Debadged
              You can just see the DRL module on the firewall right behind the adjusment point on the strut bar...
              Ian
                yep there it is thanks looks like the problem is deeper
                Debadged
                  Check the switch at the hand brake. When the hand brake is released with the ignition turned on the DRLs should light up. When you apply the hand brake while the ignition is turned on the DRLs should turn off and the brake indicator light in the instrument cluster should come on.
                  Hopefully that makes sense.
                  Ian
                    Sorry I screwed up. And isn't Lancaster, PA. in the States?
                      They also came in the kia's in Germany. I think i have the wiring diagram?
                      93 Ford Festiva WA (project car)
                      98 Ford Festiva WF (aspire)(parts car)
                      98 "Gloria" Toyota Corolla AE101 (daily driver)
                        Originally posted by navdoc101 View Post
                        Isn't Lancaster, PA. in the States?
                        Didn't they decide to become their own country last night?
                        Jerry
                        Team Lightning
                        Owner of Team Lightning
                        93 L Lightning. BP
                          ^ yeah we amish and pensultukians have succeeded from the union...
                            One less in debt state to have to deal with!
                            You all need to march on Harrisonburg and hang your "elected representatives" from the nearest sturdy structure!
                              So the American version of the Festiva doesn't have a DRL module?
