anyone ever use that stuff? ive used it once with good results back on my first card (94 dodge shadow)
my festiva is using coolant and spewing oil out the cap.. 267k miles means im not going to repair the head gasket as itll likely make things worse in the end. anyone know if the head gasket repair fluid or copper stop leak will work well as a bandaid for a while?
need to limp this until i can find/afford a new car/festiva!
