Festiva 96 EFI, wiring problem, 15A meter fuse blown every time
  • Festiva 96 EFI, wiring problem, 15A meter fuse blown every time
    hi,
    I have a festiva 96 EFI model car. now, i am having a problem with the wiring.
    the 15A meter fuse is blown again and again when it replaces.
    if the fuse blown, temperature, RPM, fuel meter and, break light indicator, other indicator lights and signal lights are not working.
    please help me to rectify this problem.
    -Thanks & Regards,
    Anytime a fuse blows it is because a hot wire is touching ground somewhere, or some amp-sucking device has been added to that circuit . Check every harness serviced by that fuse for chafed or burnt insulation. Someone on this site might know of some problem areas that will save you some time. Do not use a larger fuse or it will burn wiring.
      There should be a label on the fuse panel beside the 15 amp fuse which keeps blowing. It might help people to diagnose your problem if they knew the label.
