Festiva engine bolt torques
  • Festiva engine bolt torques
    The only thing I need to finish off my 1.3 WB is the bolt torque stages for the bigend bolts. Can anybody help?
    Also having trouble bleeding the power steering, is there a trick to it?
    From the Haynes Festy manual, page 2B-2:
    Main bearing cap bolts: 40 - 43 ft lbs
    Connecting rod cap nuts/bolts:
    ...step 1: 11 - 13 ft lbs
    ...step 2: 22 - 25 ft lbs
    Rear main seal retainer bolts: 71 - 97 inch lbs
      as far as bleeding the power steering add fluid then turn the wheel full clock both ways a few times then check the level. repeat as necessary.
      Rod
      "Confidence is the most important thing you can teach someone... if you can teach them confidence, you don't have to teach them anything else."
      1992 truckiva
      1989 festiva lx (mine again)
      1980 triumph tr7 convertible (project)
      1976 tr7 hardtop (parts car)
      1989 dodge caravan turbo
      1975 amc gremlin 4x4 (play toy)
        Also for the power steering on some fords you have to disable the fuel system and just crank the car while turning to wheel back and forth to bleed the system.
          Thanks a lot
