I am new here just purchased a 93 festiva gl automatic. It is leaking gas out of the fuel line right behind the tranny under the car. There are 4 lines running from the back up to under the transmission then I cant tell where they are going until I remove battery and battery tray, I am guessing two of the lines are break lines and two are fuel lines? It is leaking where they are all connected right before the bend up to go above fram/subframe right below transmission. Was wondering if anyone has had this issue or know the the transmission is mounted up top so i can remove part of frame to get to lines. trying to fix it without having to replace lines like cutting out the rusted leaking spot and placing rubber fuel hose in to replace rusted spot. Any help is greatly appreciated thanks.
Fuel leak
I haven't had this issue yet!
But remember the fuel system is a high pressure system, the fuel line you use needs to be be rated for FI use, not carbie fuel line. The FI stuff is more expensive because it is reinforced to take the 35+ PSI pressure the fuel pump puts it under.'93 Blue 5spd 230K(down for clutch and overall maintanence)
I replaced all my brake line and that partwas a real pain to get at. The lines run up between the body and the engine support (cross member?). I've read here it's much easier if you support the engine and transmission then lower the support to get access to the lines.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by 9festiva1 View PostAlright looks like I will be tearing it apart this weekend. Was just wondering why there is 2 fuel lines? Can't see where the meet due to cross member being in the way.
I hope this helps.Last edited by timmay89; 11-15-2011, 02:52 PM.
Yes, the 4 lines are held together to the body by clamps which you're sure to have seen. One of the clamps is at the bottom of the fire wall on the driver's side just before the lines disappear under the engine support (cross member?). It's a challenge to remove while the support is there.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
