Bearings for Manual Transmission
  • Bearings for Manual Transmission
    I'm about to pull the transmission out of my 93L. I have looked through my service manual and am a little confused as to how many bearings there I that will need to be replaced.
    How many bearings are there?
    THanks
    This is for the 5 speed...6 total, 2 on the diff carrier, 2 on the input shaft, 2 on the output shaft.
    4 seals total, 2 axle seals, 1 input shaft seal, 1 shift shaft seal.
      Hey - you should check ebay. They had the rebuild kits at very reasonable prices. Less than a kit from AutoZone. Good Luck!
        THanks
