This is on my '90 Galant, 2.0 (4G63) SOHC. Ok, I didn't really notice what it was like when I took it apart, but once I got the Galant head all put back together I realized that none of the exhaust valves were closing fully. Turned the cam through a few revolutions to make sure it wasn't just HLAs getting stuck or something, and it wasn't. So I took the cam and rockers back off (rocker arms come off as a unit with the cam caps) and all the valves seated properly. When I reinstalled everything they stayed closed until the last turn or so on the cap/rocker arm bolts, but once everything was tightened down they are all held open just a bit. Any ideas? I'm running out of guesses, I've cleaned the HLA in diesel fuel per the FSM, and all of them seem normal, and they are all the same, so no mixing up the intake ones with the exhaust ones. It just sucks because I'm finally ready to put everything back together and sell it, but I'm not about to put back together with the exhaust valves not closing
I think ya'll are right about the lifters being too pumped up. I tried installing and leaving overnight to see if they leaked down some and let the valves seat and they didn't. But one of my DSM buddies that I finally got ahold of said what they do is knock the top of each rocker a couple times with a rubber mallet, to simulate the valves banging up and down with the engine running. Told him no dice, I'd already turned the cam through about 50 revolutions with no change. He said, nope, just trust me, bang on them with a rubber mallet and everything will be fine. Lol. So I said why not... came home and did it. And I'll be darned if every single valve isn't sealing properly against its seat now. So there ya have it, a weird fix for a weird problem. So glad I stick to Mazdas for the most part lol.
