I found a 1993 fuel injected Festiva (190k miles) today that I am interested in. When you start it it will idle fine and within about 5 minutes it acts like it wants to stall. He thinks its the o2 sensor (which it could be), but the check engine light doesnt come on. Every other car I know the CEL comes on for a bad o2 sensor.
Would you think the o2 sensor could be the issue? When its trying to stall you can give it gas and it will pick up again and idle okay for a few minutes and then act like it wants to stall. He says that when your hit about 25mph it starts to get sluggish.
Another issue is that the rear hatch doesnt latch shut anymore. Is this common? Does the latch just freeze up and not lock after awhile?
Thanks for the help.
