I have a 1988 Festiva and I can not figure out a problem I'm having with the headlights. When I turn them on, the low beams work, When I pull back on the headlight lever (to flash high beams) the high beams work. When I push the lever forward for High beam, they go off. No headlights.
I removed and checked the relay by the battery and it works. I have got a couple of different manuals and neither of them has a wiring schematic.
Any ideas? Or is there another relay some where?
Thanks,
WWhunter
Thanks,
WWhunter
