My Festy alternator is starting to go on me, and all I have lying around is an Aspire alty. Could this be done?
I'm already using Aspire crankshaft and water pump pulleys due to swapping in a '94 Aspire engine. I didn't have the 92-93 crank pulleys, so I swapped the spindle from my Aspire alternator to the Festy alternator and the system worked really well. Several months pass, and now my alternator is improperly regulating the voltage to the car. My headlights brighten, dim, brighten, dim, etc. I'll post pictures of how i got the Aspire spindle to work on the Festy alty. Did the Aspire spindle ruin my alternator? :\
I'm hoping I can use the Aspire alternator.. the only real issue I've run in brainstorming is what what to do about the choke... maybe use a toggle switch and just turn the choke off manually once the car warms up? Assuming it's just a 12v lead, I haven't read the book on how that circuit works. Perhaps I should just man up and finally buy the 92-93 Festy crank pulleys I've been needing and make my car nice and solid.
What do you think fellas?
Thanks for the tips though, I appreciate it a lot. I'll report back when I get my circuit setup and swapped. The weather has been terrible!
