You guys ever expedience oil leaking from the head gasket down the block front & rear? Its not the valve cover,the head is bone dry front & back. If the head gasket is leaking oil,wouldn't I be getting glycol in my oil as well? Maybe its the Dizzy seal & I just cant see it? This is my sons Festy and I don't get much quality time with it, and just noticed this strange leak.
Head Gasket leaking oil ?
Tags: None
cam and dizzy seals are likely the culprit, BUT you can have a HG oil leak without seeing any coolent or cross contamination.Trees aren't kind to me...
Thanks Arty,I'll see what we can find.Originally posted by FestYboy View Postcam and dizzy seals are likely the culprit, BUT you can have a HG oil leak without seeing any coolent or cross contamination.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
