I just replaced my emergency brake/parking brake cable and cleaned and lubed all the linkage and moving parts.
Everything is working except that I noticed when I pull up on the lever the brake's don't "lock up", they set and will hold the car but not sure how well they would hold on a hill.
I adjusted the adjuster on the lever but it's screwed all the way in and still not locking the brakes all the way.
After reading through the Haynes manual, I don't see any info on how the self adjuster's, self adjust.
I had to release the self adjuster's all the way when I installed the new cable and thought they would 'self adjust' with normal driving.
Could that be the problem, that they haven't adjusted?
