Here is the transcript of a chat I had with Austin through NAPA's "Ask Bob" chat service.
Chat Transcript
04:40:53 PM [Austin] Hello, my name is Austin. It would be my pleasure to assist you. How may I help you today?
04:42:16 PM [John] Yesterday, I tried unsuccessfully to remove the oil pan on my 1994 Ford Aspire. I couldn't see any way to do that. Any suggestions?
04:42:48 PM [Austin] Good afternoon John.
04:43:15 PM [Austin] Please give me a moment to see what i can find for you.
04:43:28 PM [John] Sure.
04:44:33 PM [Austin] well, it's gonna be just like a normal oil pan. Remove the bolts around the outside edge, and it comes right off.
04:44:51 PM [Austin] I looked it up in my Ford repair manual.
(Note: When I first read this suggestion I was afraid this chat was not going to go so well. Later I checked his suggestion against my 1994 Ford Aspire Service Manual:
"4. Remove the oil pan nuts and bolts.
5. Remove the oil pan."
In little more than one minute he was able to look up this information in the Ford manual and type his response to me. I assume from this he has ready access to lots of manuals.)
04:45:49 PM [John] The problem was that it had been sealed at the factory with some form of RTV which sticks it together with great force. I couldn't find a way to break that seal.
04:47:40 PM [Austin] stick a big flat head screw driver in there, and pry... Then once it's a little loose, stick the pointy end of a hammer in there, and pry some more.
(Note: Interesting that he recommended the nail pulling end of a hammer. To prepare for removing my pan I went to the junk yard and removed one from a shot engine. I happened to have a claw carpenter's hammer and with that I was able to almost immediately pull that pan loose. My pan was much more tightly attached, whereas the one at the junk yard had been poorly attached using a lot of RTV. I tried my claw hammer on my oil pan but couldn't get the tip of it into the joint.)
04:50:14 PM [John] Well, I tried to get a razor knife in the place where the pan joins the block but the space was too tight even for that. Need to pry it apart a little to get anything in the gap. Couldn't find anywhere to do that. Any suggestions?
04:52:14 PM [Austin] Some how you have to fit something in there... Get a painter's putty knife and tap on it with a hammer... Like one of these:
(Note: At this point the transcript had the picture of a putty knife which linked to the following page:
http://www.plumbersurplus.com/Prod/S...4?SSAID=228548 )
04:53:37 PM [John] Thanks, Austin. I think you are right. I need to find or create a tool which will allow me to create a gap and then work from there. Thanks for your help.
04:54:12 PM [Austin] and dont be afraid to tap it with hammer. Because that's the only way it's going to come apart.
04:55:39 PM [John] Thanks for that advice. I tend to be a little afraid I'll destroy the mating surface. But with RTV that probably is less of a concern than for gaskets.
04:57:12 PM [Austin] Ya, with RTV, it actually helps if the surface is a little scratched up... Old school guys use aggressive sand paper on the mating surface to score it a little bit, so the RTV grips better.
(Note: I think this last piece of advice is what I needed to hear for me to find the courage to apply the force required to break the seal.)
04:58:44 PM [John] I'm printing our exchange to use when I get ready to try again. Good to hear from someone with an optimistic attitude. Nice Service.
05:00:46 PM [Austin] Thank you very much John... You can actually email this chat transcript to your self after we are done. Just hit the "End Chat" button.
05:02:08 PM [John] Thanks again. I will get this done!
End Chat Transcript
On NAPA's web site, this service is called "Ask Bob," I guess Bob was on a break. But I believe he couldn't have been more helpful than Austin.
Based on this experience, I highly recommend this service. If you're interested in giving it a try click here to start a chat.
Chat Transcript
End Chat Transcript
