So it's time to stop being lazy and fix this CEL before it gets too cold. I checked the codes, and I'm getting these:
02 - No crankshaft position sensor signal
03 - No Cylinder ID sensor signal
15 - Exhaust gas oxygen sensor - voltage stays below 0.55 volts (lean)
17 - Exhaust gas oxygen sensor - voltage does not change (rich)
I'm assuming the issue with the O2 sensor is my manifold. The threads were stripped, and I just forced the sensor in there. I'll replace that with a header, before I try to diagnose it. This looks decent.
As for the other two, I have no idea what they are. Haynes manual doesn't give much information. A search yieled Code 03 being related to the Disty, with not much other information. Any help is very appreciated!
