Its possible to take the multi-function switch apart and clean it.
Its likely that you may buy a new one too
HID lighting will reduce the load by 25-30 watts for the little kits
or next to nothing for the big kits as they use a separate power
source.
Any slip connector like those links that are high power should
be soldered clear through, no fuses for the best long life connection.
source.
