I put on a new valve cover gasket and now it is leaking oil all the way around it even though the bolts are turned down pretty tight. Could the gastket be too thin?
Leaking valve cover gasket
Afraid georgeb is correct.
You need to use some sort of sealant; RTV, permatex, etc. to bond the gasket to the valve cover.
Did your gasket come with new grommets?
DO NOT over tighten the valve cover bolts, the torque spec is in IN-lbs not ft-lbs.
If you snap one, easy to do, there will much use of improper language!'93 Blue 5spd 230K(down for clutch and overall maintanence)
You don't need a lot, just a thin even layer coating the groove in the valve cover.
let it start to get tacky and put the gasket in, making sure there are no kinks or puckers in the gasket.
Then mount on the head and torque it down in 2 or 3 stages.'93 Blue 5spd 230K(down for clutch and overall maintanence)
^ use coper gasket spray and make sure all surfaces are clean and dry before install. did this to Caetys aspire over 4 years ago and also to the 89 festy from Ill (missing 1 corner bolt). neither leak, period. not even a trace of oil.Trees aren't kind to me...
I'm missing a corner bolt. I'll have to give this a try.Originally posted by FestYboy View Post^ use coper gasket spray and make sure all surfaces are clean and dry before install. did this to Caetys aspire over 4 years ago and also to the 89 festy from Ill (missing 1 corner bolt). neither leak, period. not even a trace of oil.
EVO deck'd out with Bruce Lee
Last month, I replaced the valve cover gasket on one of my Festies b/c oil was oozing out onto othe head/block at only 116K miles. I purchased the Felpro model recommended in some threads from several years back. It came with new grommets. I used the tips on those threads so as to NOT have to remove the throttle body.
I did NOT use any sealant and have seen no signs of any new leaks. Sealant WOULD have been helpful to keep the new gasket attached to the valve cover while I lowered the cover onto the block -- it kept falling out.
I torqued using a quality torque wrench.
The whole process took about 45 minutes.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
it's only been a MONTH, come back to us in 3 or more YEARS and see if you have the same results.Trees aren't kind to me...
I just re-sealed Bruce's valve cover gasket. Originally I had used grease instead of silicon, on the theory that grease is much thicker than oil so should hold it in there. Nope. Went to RTV Blue today.
Gonna do Danny's on Sunday, but with RTV Red. Larry has Copper-Kote on the gasket, and it's working fine.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Copper coat or upholstery adhesive works fine, when using silicone make sure
it says "sensor safe" if you have an oxygen sensor. Silicone poisoning pulled through the pcv valve and burned will poison the o2. This causes lean mixtures
due to abnormally high o2 sensor voltages. Silicone used inside and outside the grommets and at sharp turns on the gasket is a good idea. (thin film)
Chemically clean surfaces can be obtained with an old dishwasher and an extra hot hotwater heater and something like brake clean for parts that can't be put in the washer. Any oil left on the bonding surfaces will cause seeps of oil later.Reflex paint by Langeman...Lifted...Tow Rig
