My antenna is bent up fairly bad, and I don't get every station. It's especially bad when the engine is running, which is probably a different issue altogether. What options do I have for replacing the antenna?
Replacement radio antenna
Tags: None
Last edited by TominMO; 12-10-2011, 03:25 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
